Wireless thermostat
1 May 2015
Birmingham
Hi all I have a Worcester digistat. I was having problems last year but I had a few bits of work done bigger radiator
Problem is the stat isn't very accurate I leave it on 18 degrees over night which is fine and works well if I turn it above 20 degrees it doesn't seem accurate at all and the boiler seems to run forever
I have tested with a temperature probe and the front room measures nearly 25c and on the stat it shows 21
I can either have up to 20 or above it just how long it decides it wants to run for
If I set it to 22 it just runs and runs
Anyone had an issue like this
