What is standard proactive for fitting wires in the insulation of a vaulted ceiling or flat roof for that matter. So when you have 100+ of celotex between rafters and then 50mm below then plasterboard. Where do you stick your lighting wires and then if you have some fire rated downlights do you simply cut a hole in the insulation to be able to fit them in?
Thanks in advance
Thanks in advance
