- Joined
- 20 Feb 2021
- Messages
- 15
- Reaction score
- 1
- Country
I'm planning to wire in 3 separate lights from a 3 gang switch 1 way. The aim is to take a single t&e from the mcb to the switch point and from there 3 individual t & e cables to each of the lights. Just wanted to double check how to do this using a 2 way switch (I couldn't get hold of a 1 way 3 gang. My plan was to connect the neutral from the mcb to the 3 neutrals from the light fittings using an additional connector and then to connect the live feed from the mcb to each of the L1 connectors using jumpers. I was then planning to connect the live wire from each of the 3 individual light fittings to the COM connector independently of each other (without jumpers). All the earth will be connected at the switch point using a connector too. Does that make sense or is there a better way of configuring this?
