Our old double oven that was installed at the time of the house being built 10 years ago was simply plugged into a socket with a 13A plug behind the oven. This socket is connected to a 45A cooker switch with socket. It has it's own radial circuit using 6mm cable.
We have just had a new kitchen and replaced the oven with a Neff double oven. The max load rating is 4.9Kw.
Does the cable have to be butyl heat resistant cable, the manual states it should be of type H05 V V-F or higher but I've no idea what that means. Would this be suitable? http://www.screwfix.com/p/3093y-3-core-heat-resistant-flexible-cable-reel-white-2-5mm-x-5m/80786
It's not feasible to connect directly to the 45A cooker switch that is above the worktop. What would be the best suggested option? Perhaps another cooker switch with socket to replace the normal socket behind the oven (I still need a socket there for the gas hob ignition).
