wiring double pole sockets
  • Thread starter Thread starter IFH
  • Start date Start date
IFH
4 Dec 2006
Essex
I’m daisy chaining dual pole sockets. Normally, for single pole, I’d run the cables from terminal to terminal but I’m a little unsure as to how to add in the second earth terminal.
I assume that it’s permissible to just add a loop of (insulated) wire between the two earth terminals to connect the second one. I’m planning to use a piece of earth cable from flat twin and earth for the loop between the two earth terminals.
Am I correct in this. I hope my explanation is understandable. Any help and advice would be gratefully received.
IFH
AFAIK, the 2 earth terminals have an internal link anyway, so theres no need to connect them together. Just stick both earth wires into the one terminal.
I think you mean the ones where there is a metal strip running around the top of the socket, with an earth terminal on this strip, and one integral to the socket itself. You should be able to see where the metal strip tees off into the socket itself.
