Update on bathroom, we've got as far as removing all tiles, plasterboard and removing chip-and-grove floorboards (lots of fun!).
The consumer box is on the ground floor pretty much directly below the bath (hope it wont leak). We want to install a trinton 10.5kW shower.
I've spoke to an electrian who said we can lay a 10 mm two core cable through the floor into the roof. He just said make sure it doesn't run with pipes and goes through the joists.
He'll come and make the actual connections and certify part p.
I was thinking we could run it up the stud wall.
Also he said if the towel rail is over 3kws we'd need to run two 2.5 mm cables (he said he'd make a ring main) - I assume these are two core as well.
Does this all sound sensible?
Thanks in Advance - this board is great
Mark
Mark
