Hi there!
I have an existing hob and double oven both electric. The hob is rated at 6Kw and the oven 2.7K. They are supplied by 6mm cable with a 30amp MCB at the consumer unit. The cable run is around 7-8 meters mainly in the ceiling and down in a stud partition wall, no insulation involved. The cable goes into the switch unit for the oven then is looped out to the switch unit for the hob.
Reason for the post is I've just tried to replace the switches with more modern units but there is no room in the terminals for two 6mm conductors and no space in the new back boxes for three cables at the cooker switch. I hesitate to ask but can I put the supply cable into a suitably rated junction box and take two 6mm cables from there to the oven and hob switches! Or more fundamentaly is the 6mm cable big enough? We never had the MCB trip and I read a bit on here about diversity etc. We are in the process of refitting the kitchen so would it be worth us uprating the cable. By 'us' I mean the Part P registered sparks when I find one locally! I know my limits!!
Thanks, Roland
Thanks, Roland
