Hi all.
I stay in a 3 bed flat and I'm currently converting 1 room as a workroom for electronic circuit testing.
I will require 6 x double sockets and a feed for a couple of flourescent lights.
Sockets..
The idea i had was to take a feed from a 30A breaker in the main CU (6mm T&E) to a mini CU immediately next to it with a 40A RCD then through to the workroom (6mm T&E) to a 45A double pole isolation switch then to the sockets as a mini ring with 2.5mm T&E. (Ring connected directly to the 45A switch)
Before anyone asks I WILL get it certified when ive wired it up. I have, however been advised that this is unsafe due to the fact that their is no isolation possible for neutral?? - I'm a bit stumped here!!... Am I missing something? - Do you think a double pole isolation switch between the CU and RCD is the answer or a dedicated CU in the workroom?
The reason I'm doing it this way is that the flat has NO RCD protection at present in the main CU but I wanted to add it to the lab..
Scott
Sockets..
Scott
