Is 1.5mm sq T&E adequate, as 2-core, for a security light with built-in sensor (circuit protected with RCD in CU)? Will 2-core be adequate if I want a separate sensor too? Thanks.
I'm not quite sure about the original question.
1.5 T & E is a 3 core cable, which will be sufficient to supply the PIR light.
If you require the sensor of this light to control other outside lights you will need an additional cable from the light.
Your light fitting should tell you the max. wattage that can be controlled by the PIR. If your additional lighting load exceeds this, you wiil have to use this additional cable as a control wire for an impulse relay or contactor.
that's a fair comment, but the origonal posted question the cable changed from T & E to two core?
as for the additional sensor that would depend on brand of pir / light chosen, if you want multiple sensors i would opt for a system designed to be used as such, not try to add a stand alone sensor to a atand alone pir / light, which is what it appears you are trying to do
breezer, JC GRAY: I thought T&E was referred to as 2-core. The Electrician's Guide, page 63, Table 4.7 gives 2.5mm sq cable as 2-core. I meant is 1.5mm sq T&E cable suitable for an outside PIR type floodlight with/without a combined darkness switch and with/without a movement sensor. They seem to vary in this respect. If I wanted a separate switch and/or sensor, then would this cable serve. Thanks
Sorry? you just said three core is three core and earth?
Did you mean 3 core is 3 core: 3 core and earth is 3 core and earth?
More to the point, the post asked if 1.5mm was adequate. Where is the power coming from? if it is from an existing lighting circuit wired in 1mm already, then using 1.5 will not magically give you more available current. If you are using an existing lighting circuit, then check it is not already loaded too much to support the floodlight.
i personally do not like flood lights in domestic premises.
I was at a mates house on bonfire night, every time he went to light the next fire work, so next doors flood light came on, lighting his garden.
yes ok the sensor could be angled down, but it was the "surplus light" that i found annoying, its a pity some one does not make "barn doors" for external flood lights
