Hi, Im trying to workout how to wire up 3 way motorized valve. I have a system boiler that i have effectively converted to a combi using a plate heat exchanger. The 2 issues are, the boiler can only be controlled via the room stat connection so effectively a short across the 2 terminals, rather than a positive control feed. Second issue is the hot water uses a flow switch to trigger demand rather than using a tank stat as would normally be the case. I have a relay I can use which has 2 sets of contacts but just can't work out how to wire it all up. Can anyone offer a diagram. Thanks
