This is the Y Plan mid position three port valve, the two port valve is easier,
there is also C and W plan, if S Plan which seems most likely then we have brown, blue, grey and orange and the thermostat feeds the brown wire.Yes, that seems correct.I got to remove the black and connect to 3 (heating on)
Then link blue to N (like a Spur)
then link grey/brown to Perm live (like a Spur) with a link to common.
is that correct?
You mention ebus, but we don't know if your existing thermostats use it. There is definitely a switched live, back to your boiler from the wiring centre.i have two thermostats and not sure what to do when I look at the ebus on the boiler
Far more likely to be a combi with dual zone heating on a new-build, built after 2014, with that wiring centre.there is also C and W plan, if S Plan which seems most likely then we have brown, blue, grey and orange and the thermostat feeds the brown wire.
