Hi all,
I am installing a brand new oven, hob and extractor in the kitchen - on the opposite side from where the current stand alone oven hob is. This is what I understand so far:
I need to keep the oven & hob on the separate circuit into consumer unit it is on now - ie disconnect existing wiring and start again - i assume this is ok?
can I put the fan on this circuit too?
My plan is to run the new cable from the consumer unit (which is just behind the wall where the oven will be) down the wall into the kitchen and into a 45A switch then down to a dual appliance cooker connection unit for single oven and ceramic hob? does this sound OK? Also, if I chose a 2 gang switch could I then run a separate cable (all cable to be 6mm and 10mm from consumer unit to switch?) to an unswitched socket behind the 'flu' of the hood?
Any help greatly appreciated. Note; I will probably not end up doing this myself if I do not feel comfortable with the instructions but I am hoping I am nearly correct?
