Wiring separate double oven and hob
23 Jan 2003
I see there are many posts related to this but some contradict each other and I want to be 100% safe. When I moved my old double oven the 6mm cable behind sits on the plaster (accessible). Can I with a cooker jb run both a cooker and a hob off this one cable? If so what additional fcu's or similar will I require. If the answer is no, what do I do. Do I run an additional 6mm cable from the consumer unit (same circuit breaker)?
Please advise :(
The lack of response to your post is due to the fact you have not provided any information about the ratings of your appliances.
How much is your cooker rated at?
How much is your hob rated at?
How big is the cooker circuit cable?
How big is the device protecting the circuit?
Etc...........
