I have a new 10mm cable from consumer unit to cooker control box. The whole protected by a 40 amp MCB.
I wish to connect up an induction hob (8KW) and an oven (1KW).
I propose (since 10mm cable is difficult to manipulate) to connect my cooker control box to a second cooker control unit with socket under the worktop between oven and hob . Effectively using this 2nd control unit as a fused junction box.
The forward connections will be a 10mm cable to the hob and a 13amp plugged cable (as supplied with the oven).
Any problems with this configuration?
