In need of advice/help please. Our gas boiler is wired as per the attached diagram. Boiler is controlled by a basic programmable timer which can run the CH and/or HW. Timer works fine in this respect and CH and HW both working fine.
The problem we have is that the boiler seems to have a permanent live feed - as even when timer programme positions are off, the boiler fires up for about 2 or 3 minutes every 15-20 minutes or so. Doesn't seem right to me - it's annoying and will also be using up gas.
I don't understand the attached wiring - the arrows in the diagram are wires off that have been cut but perhaps were once connected to a thermo/frost stat. Wire colours are as shown in the diagram.
Any help or advice much appreciated - easy fix or get a sparky in?
Thanks you in advance. J
