wiring under cabinet lights
28 Jul 2007
Warwickshire
I want to add wiring to supply some low voltage under cabinet lights.
I was thinking of taking a 2.5 mm spur from an existing socket that's on the ring. It would then go through a 20A DP switch and up to an unswitched 13A socket above the cabinets which the transformer would plug into.
Is this a valid solution?
why dont u just take a fused spur off the ring main and wire the lights straight into that with a 3 amp fuse
The lights I was looking at are prewired with 13A plugs. It seemed logical to install a remotely switched socket rather than chopping the plugs off and hardwiring them.
I haven't actually got the lights yet. I just wanted to get the wiring in place so that I can finish the decorating.
where is the 20 amp switch going? u installing this?
better to install a fused spur with a 3 amp fuse and then
u can take it up to a socket if u wish to plug in ur tranny.
remember to fuse the plug at 3 amps too tho
Thanks for the input.
The 20A DP switch would be in the wall effectively working as a light switch.
I was working under assumption that if I install a 13A socket then it should be wired to support 13A even if I know the load won't be anything near that. Thus the 20A DP switch. I could well be wrong.
I was trying to avoid having a switched FCU in sight as a plain switch would look neater.
It is frowned upon to have 13A sockets that can't actually supply 13A particularlly if they are (or may become through furniture moves) easilly accessible.
what you propose in your original post is fine and done in kitchens all the time.
i can see your point. do use 2.5mm to your socket but remember to fuse down for your lights at your plug top
