Hi all,
I purchased some Wiska 308 junction boxes and non-Wiska glands (16mm).
I have only used Wiska boxes once before and don't recall having a problem when trying to screw the gland in but I can't remember which glands I used. Should the glands have been larger than 16mm? I ended up trying to smash through the opening with a small screwdriver because I couldn't get the gland to screw in. I then discovered that I have cross threaded it and the otherwise unnecessary back nut will be a pig to fit.
I appreciate that Wiska claim that their boxes are IP whatever without needing to use a gland, but I would feel more confident using compression glands. I am also aware that their sales patter says that back nuts are needed because the knockout holes are threaded, but in my case the one gland that I have managed to fit sits at a slightly jaunty angle..
