Hi.
I'm installing two 150 watt external lights fed via ring main/rcd outlet to 1.5 hi tuff cable.
I intend to site two IP65 junction boxes next to each light fitting, feeding the hi tuff to each box and then feed the lights from the junction boxes with some arctic flex.
The IP65 have flexible membranes at the holes around the box and also in the back of the box.
My question is do the membranes have to be cut and then fitted with a compression cable gland/lock nut, or will the cable just push through the membrane, which appears will fit snugly around the cable. I cant see any way of ensuring the cable gland will remain central to the membrane, which appears to large for the gland.
Perhaps junction boxes with 20mm solid knock outs would be better for cable glands? if there is such a thing?
Hope this makes sense!
Thanks,
DV
Thanks,
DV
