    Dismiss Notice
What conduit to protect last metre of cable to garden spike lights?
Discussion in 'Electrics UK' started by pedr0, 21 Jun 2021.
  1. pedr0
    pedr0
    9 Jul 2008
    113
    Thanks Received:
    2
    Country:
    My garden lighting is going to have about 8 230v spike lights like this. The cable around the edge of the garden is going to be armoured SWA looping in and out of junction boxes. The flex that's attached to the spike lights are then going to be wired to the junction boxes.
    What conduit can I use to protect that metre or so of flex between the fitting and the junction box? I'm in an area with foxes and given that it's an urban area there are probably all manner of rodents. They seemto love messing up anything of mine that's new.
    Would plastic flexible conduit like this be sufficient? Armoured stuff like kopex seems really expensive.
  2. Sponsored Links
  3. sparkwright
    sparkwright
    20 Aug 2009
    8,596
    Thanks Received:
    1,082
    Dorset
    Country:
    I doubt you can successfully cover every inch of the flex, if this is the case, why bother?
    The lights aren't designed to have conduit over the flex, it's supposed to be exposed.
    You can slide some conduit over the majority of the flex if it makes you happy, but it won't be watertight, so don't bother trying to connect the conduit to the waterproof junction boxes.
  4. studentspark
    studentspark
    13 Mar 2010
    589
    Thanks Received:
    15
    London
    Country:
    It can help a little bit, but generally nothing but armour plate will stop the squirrels.
    Keep the run from the junction as short as possible and clip to a fence, if you can. They seem to nibble more at loose cable.
    You can get a smaller diameter copex, which looks a bit neater.
    Might be worth considering 12v spikes, but that comes with added installation issues.
Loading...
Share This Page
