Hi All,
I'm replacing an existing 6ft fence which had rotted posts. The posts were set into metal spikes which are set in concrete. I've put new 3" posts into the spike's bracket and tightened the clamping bolt as much as I can. However the post still wobbles a bit and I'm not sure what else to do to firm it up? The bracket does not move, its the post moving within the bracket.
The post sits in the braket of the spike around 6" and is 7" in total length. Will it be more rigid once the new panel is attached?
Any help gratefully received...
Cheers
Cheers
