Wonders of the Universe
Radiowaves don't work in a vacuum
Sound waves don't transmit in a vacuum, but electromagnetic radiation does.
Electromagnetic radiation includes radio waves, microwaves, television waves, light, X-rays etc.
So a radio would be able to pick up a signal in space, but you wouldn't be able to hear it unless the radio speaker was in an area of enclosed air, e.g an astronaut's helmet.
How come radios had Vacuum tube valves then :?
For the optimum performance the space between the cathode and the anode should be a vacuum. If there are any gas molecules in the space in which the electrons travel, collisions will occur and this will impede the flow of electrons.
Sound is only produced in the speaker via an amplifier providing
the speaker is in air.
That infers that the screen produces volume? Sound waves CANNOT travel though a vacuum. FACT.
You can infer or in you opinon say the screen(????) produces anything you like, even sausages. But in FACT all the valve does is produce electrons from the cathode and if they were noisey little things you wouldn't be able to hear them anyway because they are in a vacuum.
Then you get to my next statement.
Which one is it then Mick?
Both are correct, sound/radiowaves, distort the air around them, to produce a sound. There is no air in space, it's a vacuum. Sound doesn't exist. Remember the quote 'Nobody heard you scream in space' ?
Only light can travel through a vacuum. Not sound. As soundwaves have nothing to bounce off. As it's a vacuum.
Good to see the ignorant posts, that know nothing. Keep it up, it just shows how stupid you are, last 3 posters. Are you going to keep this abuse up? Or are you going to finally realise how stupid you are?
You watch these rubbish Star Wars like programmes, and think that's reality? You can't have an explosion in space, as there is no surrounding oxygen to ignite a fire, so an explosion is an implosion, because, you guessed it, a lack of oxygen, and lots of vacuum.
So if radiowaves don't work in a vacuum, what's with those satellites about, oh, 22k miles away which we use to watch TV? Although I suppose you'll bring up the exosphere but it's not like there's much of it out there.
You may want to note that radiowaves are electromagnetic radiation. So is light.
I think the communication is via microwaves. Have you any ideas? It certainly isn't radiowaves. Microwaves can travel throught a vacuum.
Both microwaves and radiowaves are electromagnetic radiation, as is light. Merely at different points of the spectrum.
Both are correct, sound/radiowaves, distort the air around them, to produce a sound. ...
You are wrong about radiowaves. I can understand that you might be ignorant of physics, but shocked that your lack of awareness of the universe around you has stopped you noticing radio communication satellites.
Your foolish repetition of a completly wrong statement makes you look ridiculous.
