Wood Door Liner/Frame
21 Jan 2013
Cleveland
I've had some door liners fitted within stud walls..
Problem being, one thats fitted is ok, but at the bottom the upright section must be slightly warped as it's not straight on the edge architrave would be fixed too, within 3-4mm for the bottom 200mm of the door...
Will this cause any problems?
Also one of the doors the top section is not perfectly level and runs out by about 10mm from one end to the other, will this cause problems and am I better off getting them refitted ?
Crazy ,Its really difficult to get door work of cold callers,Looking for a price,The nutters are so cheap, but it all end's in tears,
Its been plastered now, what if I carefully cut the plaster around the frame with a stanley knife to separate. Then unscrew it, as the header doesn't have much room to level against the top stud, so maybe I could cut a little off the bottom of the frame to give me enough play to level correctly... I know I shouldn't have to, I'll get a photo later as I'm away till next week..
