I've had some door liners fitted within stud walls..
Problem being, one thats fitted is ok, but at the bottom the upright section must be slightly warped as it's not straight on the edge architrave would be fixed too, within 3-4mm for the bottom 200mm of the door...
Will this cause any problems?
Also one of the doors the top section is not perfectly level and runs out by about 10mm from one end to the other, will this cause problems and am I better off getting them refitted ?
