I recently hired a professional to lay solid oak wood flooring throughout oour ground floor level, and after around 7 weeks, a long section has warped massively, bowing up like a volcano about 3 to 4 inches high.
The 'pro' has proved reluctant to come and address the issue. After one visit, he has expressed a belief that there must be a leak under the flooring, but my belief is that it is due to the lack of an adequate expansion gap left by the guy who laid it (he showed lack of due care and attention during the process). He said he will come back to make damp readings, and if there is no leak he will make good the problem. I'm confident there's no leak, but I understand that concrete holds residual moisture. Am I right in thinking if there was an ambient amount of moisture in the concrete before he laid the floor, the pro should have applied a membrane or treated the surface first?
I'm hoping one of you pros can offer me some tips to look out for, or things to bear in mind when this guy comes back - such as what the readings should be - as he seems very reluctant to admit fault and I believe he'll try and fob me off. The giant eruption is around two metres long and is very similar all the way along, but despite this the wood is only touching the wall at one end. To me, this indicates the expansion gap was uneven in the first place, or the wood would be touching all the way down.
He also told me that the wood would not expand lengthways, so I showed him the floor is also pressed tight against the wall at the end of the planks as well. To me this indicated there must have been an inadequate gap in the first place if it couldn't have expanded that way. He then tried to change his story.
Sorry for the long post, but would massively appreciate any thoughts so I have a more fact based knowledge before he comes back...
Thanks guys.
Thanks guys.
