Hi all,
Going to lay hardwood flooring on a well insulated screeded floor of 40m2, we have wet underfloor heating in situ (i.e. pipes with water rather than electric).
Not too sure how to lay the floor, i want to glue thin wooden battens to the floor and then glue the hardwood to the battens in the opposite direction, however this will leave a small space between the screeded floor and the wood of about 5mm which i intend to partially fill with 3mm of underlay especially designed for under laminate flooring over this kind of underfloor heating. Anyone any idea if this will have an impact on the heat at ground level? Anyone got a better suggestion, all are welcome.
Thought about glueing the hardwood directly to the floor with Sikabond T54 but i was worried this would be overly expensive and that the hardwood may actually part from the screed over time.
Thanks guys.
Gav
Thanks guys.
Gav
