wood hardner (not filler)
5 Dec 2010
Anyone know how to make this up ?
I make do with a mixture of fibreglass epoxy and acetone and am quite pleased with it but would be happier with something closer to the actual product - which is very volatile and penetrates rotten timber very well.
But I often run out of it and so have to make do with substitutes as the shops are a long way away.
The fibreglass and polyester resin is a much superior product. You can thin it with styrene.
I'm pretty sure the wood hardeners are nothing more than spray acrylic like you use on cars as a top coat.
You can get two part paints that penetrate well.
thanks a lot .Where would I get strene (in a liquid form)? Would I be able to find it incorporated as a chemical into household (or other) products if it is hard to get on its own?
[/b]
genuine wood hardener is meant to be used after you have removed 95-100% off the rotten wood to give good structure for the new wood to adhere to :wink:
