Hello again
Can you help?
On the top of the bottom wood frame at the sides are 2 plastic bolts that conceal a metal pin. If the little round securing disc is turned and the plastic levers are moved inwards it is possible to let the top of the bottom frame swing inwards.
Is it possible to remove the whole wood and glass section easily or would the spring be lost for ever? Is this only used during the installation or can it be of help in cleaning and painting etc.
Many thanks for any help - Rob
Can you help?
