I've had a search through the posts for tips on cutting the hole for an undermounted stainless steel sink in a 40mm walnut worktop.. none seem to quite fit. The closest seem to advise drilling holes for the corners and either jigsawing the corners then handsawing the straights or just using a jigsaw for it all.. (if I did that would I cut it slightly small and sand the last couple of mil?)
I've also seen talk of routers/jigs, but not sure how this would work/where I could get them/if it gives a better finish?
I have seperate sink templates (there is also an undermounted stainless drainer) any recommendations on a suitable gap between the two to retain enough strength in the top?
also, the instructions advise a bead of silicon to seal the sink to the underside of the worktop, however I was planning to seal the wood with oil a few times top and bottom + edges so presumeably this would struggle to stick?
any thought appreciated
many thanks
Trev
many thanks
Trev
