- Joined
- 8 Mar 2020
- Messages
- 98
- Reaction score
- 1
- Country
I was told by a joiner that he uses Woodex softwood to create sash windows.
I was wondering, is this good material?
WoodX is the trade name James Latham has given to its engineered timber.
The softwood engineered timber they use is made of exactly the same timber species: pine.
It certainly has advantages over solid pine:
the engineered timber is made of 3 laminations, the face pieces are virtually defect free: ie no knots, no resin pockets, no splits. It’s far more stable than making windows out of solid softwood
Does your joiner use finger jointed or solid? - I’d guess fingerjointed, in softwood the fingerjointing can Telegraph through the paint finish visually
I wonder how honest your joinery company is being….
sliding sash windows are constructed with either weight boxes, which are thin timber - so wouldn’t be laminated. Or spiral balance which are big sections not likely to be made from engineered unless they use door bottom engineered section.
the cill can’t be engineered as the glue line would be exposed.
so the only Woodx parts would be the sash stile and rails
Personally I would strongly recommend engineered Siberian larch over softwood - but I doubt it’s available due to Russian sanctions
when I ran a joinery company I used to import engineered Siberian larch from Germany - a fantastic product, it’s as dense as hardwood, growth rings just 1mm apart and very stable.
First time I hear about the "Light" windows.Can you clarify what you referring to please.
By 'Sash' do you mean a complete window where the opening section slides (either vertically or Horizontally >Yorkshire Sash) or just the sub-frame that the glazing is in?
What I'm seeing more often is the sub-frame which I know as the 'Light' is referred to as 'Sash' even in casement windows. I'm confused as the son of a midlands C&J who always referred to the sub-frame as a 'Light' and a Sash window was the complete window.
If you are making sash windows yourself, or parts for them, get some accoya. Arnold Laver will sell it to you in small quantities. It has many advantages, including easy to machine and does not move about with humidity (or only very very small unnoticeable amounts). It's not cheap but once made they will be extremely durable. If you do go this route, post again with more information about what you are doing, because I have a fair bit of experience using it for my own windows and doors, including sash windows and happy to pass on what has worked for me.
