Worc Bosch 28i No H/Water no rads
9 Jul 2006
Lancashire
Anybody help, no hot water no rads. The power light is on , the pressur is on 2 the heating will click on and sounds as if running, rads cold , no hot water .
No obvious leaks, as worked perfectly for the last 4 years
any ideas?
thanks
You have been a little too economic with your description.
You say there is a "click" when you select heating.
You dont say what happens when DHW is used !
Perhaps the pump, gas valve, pcb, fan, aps or any of the many parts within the boiler has failed?
I would say that you will need a half competent boiler engineer as such a simple fault will be easy to find. Six minutes after taking case off I would hope.
Tony Glazier
Tony,
Thanks for the reply,
The noise from the boiler clicks on as it always as and is the usual sound when the rads and hot water would work. I run the hot water tap for ages no hot water and rads stay cold. I have taken cover off to see nothing in the view window. Should there be a flame? No knowledge of this type of thing sorry for being vague.
thanks
Paul
Check the overheat stat hasn't popped out, Little button on top left of the boiler.
I have had a look at that reset button, its a red button standing proud about a 1/4 of an inch, should this be flush.
thanks
Paul
Tried to push the button in but it is solid, it as a retaining nut at the base , should this be loosened to help push the button in?
for any help
