Hi All,
I am hoping someone can help me,
My boiler has just developed a water leak.
I have removed the cover and then the inside cover and the drips appear from just above the burner - on the right hand side.
I have created a small channel with tin foil that lets it run out but it means keeping both the back panels unscrewed - this is exposing the combustion chamber cover. Is this dangerous?
Can a novice remove the Combustion chamber cover to have a look inside or am I being foolish?
Here is the manual (if that helps)
http://www.worcester-bosch.co.uk/ca...instructions-for-cbi--discontinued-dec-06.pdf
I appreciate you reading this,
James
James
