Worcester 240 Boiler Cut Out Fault
16 Mar 2010
Lancashire
My Worcester 240 Boiler has developed a habit of cutting out. When the red cut out switch is depressed the boiler fires up again and operates normally for another few hours.
The pattern seems to be that it only cuts out when the boiler is lit for a longer period (e.g. later in the evening or at weekends when the central heating has been on for some time).
I had a new Gas Valve fitted a couple of months ago but all seemed well for several weeks until this problem started.
Doubt it's relevant but the combi boiler only serves the cental heating to the house and hot water to utility room and an infrequently used shower room. Main hot water supply is from a gas AGA.
Any ideas as to the cause of the problem would be very much appreciated.
Thanks,
Rob
This red cut out switch, is it on top of the boiler? I pressume it's intermittantly overheating then. If so, there's lots of things it could be. Mucked up system, dodgy pump, boiler stat failed.... What's the system pressure like?
