Hi guys,
We have been experiencing issues with hot water for the past week in that we have had to turn the hot water tap on a lot more to get the boiler to turn on and supply hot water (when the central heating is off). When the central heating is on the hot water comes through but not as hot as usual.
Now, while the central heating is off and we turn the hot water tap on full whack the boiler doesn't come on at all. The little spindle comes out of the diverter valve just a little bit. This for me explains why the hot water is tepid when the central heating is on as the microswitch the spindle should touch allows more gas to burn giving proper hot water instead of tepid water.
I've had this happen little over 10 years ago and I replaced the diverter valve, which sorted the problem. It then became apparent that you can get a diaphragm kit to replace the diaphragm in the diverter valve.
I've read this forum post from two years ago:
http://www.diynot.com/forums/viewtopic.php?p=836938#836938
First of all, is it really that easy to replace the diaphragm on this diverter valve and where is best to get the diaphragm kit? Also, is there any different qualities or brands or are they all a generic diaphragm?
Thanks for your time in reading my post.
Hope to hear from you soon.
Jaysta
Jaysta
