    Dismiss Notice
Vaillant 242 Turbomax hot water intermittent
Discussion in 'Plumbing and Central Heating' started by primetime, 16 Jul 2016.
  1. primetime
    primetime
    20 May 2013
    91
    Thanks Received:
    2
    Bristol
    Country:
    The hot water for the shower doesn't always come on but is ok for the other hot water taps - basin and kitchen sink. The shower has the lowest flow rate.
    I suspected the diverter valve diaphragm but there were no splits or tears. I replaced the diaphragm and everything else that came in the diverter service kit. The hot water seemed ok for a few days but has gone back to being intermittent.
    The microswitch doesn't seem to operate the times the DHW doesn't come on despite re-adjustment.
    The Central Heating radiator supply pipe also gets warm for a little way (heating not on) when the DHW runs for a little while.
    Replacement of entire diverter required?
  2. Sponsored Links
  3. hertsboilers
    hertsboilers
    26 Nov 2011
    2,568
    Thanks Received:
    952
    Hertfordshire & London
    Country:
    Yes, whole valve time.
  4. Bunnyman
    Bunnyman
    22 Mar 2010
    5,488
    Thanks Received:
    1,839
    Northamptonshire
    Country:
    Yes 011289 is what u need
  5. primetime
    primetime
    20 May 2013
    91
    Thanks Received:
    2
    Bristol
    Country:
    Thanks. I had another go at adjusting the microswitch. Seems ok for now.
  6. hertsboilers
    hertsboilers
    26 Nov 2011
    2,568
    Thanks Received:
    952
    Country:
    So you will still get warm radiators when you fill your bath.
  7. Sponsored Links
  8. primetime
    primetime
    20 May 2013
    91
    Thanks Received:
    2
    Bristol
    Country:
    Rads not getting warm, just a short section of the supply from the diverter.
    • Like Like x 1
  9. Bunnyman
    Bunnyman
    22 Mar 2010
    5,488
    Thanks Received:
    1,839
    Northamptonshire
    Country:
    Well you asked for advice mate, just change the valve, i know its expensive but u will do the same as many professionals, fanny around convincing urself it seems ok, the problem is there
    • Like Like x 1
  10. primetime
    primetime
    20 May 2013
    91
    Thanks Received:
    2
    Bristol
    Country:
    I appreciate the advice. I got to the same conclusion but wanted to hear it from someone with more experience or if there something else that could be done. Not saying I won't replace it but in no rush just yet. Have sourced a new diverter assembly. Thanks again.
    • Like Like x 2
  11. Agile
    Agile
    26 Jun 2004
    63,560
    Thanks Received:
    4,511
    London
    Country:
    I have successfully adjusted the switch in a few cases. But I also agree that on that model its better replacing the whole valve.
    Tony
  12. AGAS
    AGAS
    21 Feb 2014
    9,689
    Thanks Received:
    1,706
    down south
    Country:
    don't be like some wally's on here who don't take the advice from someone who knows what their talking about with vaillants ( bunnyman ) , because if you go the cheap way you will only spend ( cost & money ) much more in the end .
    there are plenty of examples on this forum
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
