No Hot Water unless Central Heating on
12 Aug 2010
London
Vaillant 242/1 E
If the central heating is turned on then hot water can be operated ok. If the control is turned to just Hot Water then when a hot water tap is turned on nothing happens. Is it the diaphragm or diverter?
thanks
but if the HW comes on all ok when CHW is on then diaphragm or sticking pin seem good possibilities?
Also check all the cappilary tubes they generally get blocked up and the servo doesnt make switch, god these boilers were over engineered, also not all parts available 4 these any longer is it not a VCW
