Good Morning
Worcester 24CDi which up until yesterday has presented no problems! Both the Central Heating and Hot Water supply are both not working.
At first I suspected it was a water pressure problem - the pressure had dropped to 0.5 and after a bit of research, found out how to refill the boiler using a key and the Grey Knob - is now holding steady at 1.5 - which seems to be the recommended level.
However, I am still having no joy. When I switch on I get the following info...
The Red Light beside the Heating dial goes Red Immediately and stays on.
The Red Light by the Water Heating comes on after around 10 - 15 seconds but flashes very quickly and constantly.
The light indicator (flame symbol) does not come on at all - even when the Hot Water Tap is turned on to stimulate the boiler into action.
There is a small red button that I have assume is a reset button - pressing and holding this has no effect - is there a procesdure for doing this though?
I don't have a manual, so can anyone advise me further before calling in the Cavalry?
As you may have guessed, I am not an expert, but can follow instructions!
Thank you!
Thank you!
