worcester 24i junior non condensing
9 Jan 2014
Hampshire
hi all
i am trying to fit a wireless roomstat(honeywell homexpert non programmable volt free) to my worcester combi but worcester only have three connections on the wiring diagram and honeywell require 4. i am sure i just need to link something together, any advice would be welcomed
cheers
No you dont link anything you need 4 cores from the boiler to the stats receiver unit
L+N of the unit need a L+N supply from your boiler and your boiler will have terminals marked RI and RS if i remember correctly, there might be a link in there if there is remove it and connet to the terminals T1+T2 on the new receiver unit
cheers ian
my 24i junior does not have 4 supplies at theboiler for the reciever, the boiler terminals are as follows NS,LS AND LR
what in the name of moses is going on :?:
i think i should wire it to control the burners directly but dont want to risk frying the pcb
i think i should link the LS into thefirst switched terminal on the reciever and put the LR from the boiler to the 2cnd switched terminal
the roomstat is a honeywell homexpert THR842DUK
im not going to open the roomstat packaging until i am sure that i can get this to work
cheers
Ls is the common live supply. Connect this to both L and T1. Connect Ns to N. Connect T2 to Lr. Remove any link between Ls and Lr.
Ns = Neutral supply
Ls = Live supply
Lr = Live return.
mogget
many thanks, just as i suspected
thanks once again for your kind help, i shall now open the box in the morning
cheers
Look what I found in my album - must have answered this question before somewhen!
OP, I hope you got it working, just posting this in case anyone searches in the future.
