Hi everyone. I'm hoping someone can hep me with this problem.
My boiler wont fire up unless you apply pressure to the front of the timer. ive been wedging a stick against it and if you get it right the heating will stay on. if not it'll keep cutting out. the timer on the boiler is the circular dial with teeth all around it that you press in to set a time. it also has a little plastic switch that you push down to ignite the boiler.
Its also making a constant clicking noise that sounds like its coming from the timer.
Can anyone diagnose this fault and is it DIY fixable... cheers
