Worcester 28 cdi
6 May 2009
Lancashire
Hi, All
I have just got a new gas valve for my boiler worcester 28cdi but the solonoid connections are different. Can anyone please tell me what the correct location of the plugs are, starting from bottom to top? I understand it to be: purple wires bottom, brown- middle and blue-top. Is this correct? Also do the burner pressures need setting on the new valve which is no. 87161026730
Any help would be gratefully received,
Cheers Stan
sounds like you have the wrong gas valve!
2. are you Gassafe registered? as you should be to change this part!
3. yes the new valve will require setting up to the right gas rate again if you are registered / trained you will know how to do this.
you have the new type gv which replaces the dung one you have at the mo
but if you dont know that you shouldnt be touching it and i as sure as hell not helping you do it
sorry but its just not safe
