Good evening,
I am after some help/advice.
I have sse home shield boiler care.
I have the above boiler serviced annually. 2 weeks ago I had intermittent hot water. The divert valve was replaced by SSE, it was noticed the expansion tank wa leaking, this was also replaced.
When the heating engineer had replaced the part he checked the hot water, all fine. He only ran the tap on for 15-20 secs on to prove getting hot water.
That evening I went for a shower. Hot water came on, then after about two minute hot water went off, 15-20 secs hot water returns.
This carried on for the time I was in the shower.
SSE came out the flowing day, after a little bit of tinkering they said the plate heat exchanger is fault. Before I go and spend a considerable amount of money on getting this replaced I just wanted to confirm there is nothing else that could be causing this fault.
I should mention when running the bath tap the boiler does not cut out.
Any info greatly received.
Russ
Russ
