just had new boiler fitted not sure if this is supposed to occur but everyday at the same time the fan kicks in for 5 minutes or so then cuts off is this normal or do i call worcester engineer out thanks for any help
I know the pump should run in such a manner ..... It's part of the pump siezure protection. Maybe it's that you can hear or possibly there is a similar or connected feature for the fan. I wouldn't be worrying about it in any case.
