My boiler is situated in the loft of a normal 2 storey house. I get hot water quite quickly upstairs, but it takes about 3 minutes of full flow before any hot water comes through downstairs. Is there something wrong with the system or the boiler? Thanks
Planned obsolescence. The boiler manufacturers cartel got together several years ago, oh about 1983, they decided to apply planned obsolescence to all their products. Make a boiler with a limited lifespan & condensing boilers are turning out to be the rose in their crown!!!
German manufacturers are masters of this method of manufacturing.
Guess who invented the phrase 'German Engineering'?.....
It sounds like a simple case of your boiler being further from your downstairs taps than your upstairs taps to me. If this is the case, then the cure is to move the boiler, or find a more direct route via which pipes to your downstairs can be run (and accept that you'll have pipes running down a wall somewhere)
