hello was hoping one of you very knowledgeable gasmen could give me some info please.
ive had a few gasmen to check my boiler over the last couple of months, and I seem to have one of those problems which is ok whilst they are at my house so I end up paying them for doing very little so was looking for a bit of ammunition for myself so that I have some sort of idea as to whats going on before they get here next time:
anyway the boiler is a Worcester 28i junior, couple of years old. started a while ago my water from my hot tap seems to get scalding hot and then the boiler just stops working for a bit. the boiler cools down and then I get more hot water then it turns to scalding and then eventually shuts down again and this keeps happening.
what I have noticed is the flow upstairs in my bathroom from the hot taps is terrible (water barely trickling out some times & not enough water coming out to wash yourself in the sink) and downstairs in the kitchen is poor but not quite as bad as upstairs.
I understand that the slower the flow the hotter the water is so am I right in thinking the water is so hot as the flow is so slow and so there is a blockage somewhere which is causing the hot water flow to be so slow coming out of my tap?
did a bit of reading on forums and people have mentioned things like plate heat exchanger being scaled up could cause the flow to be this poor and others have mentioned possibly the pump? does any of this sound feasible to you experts? would just like a bit of info myself like I said before as getting fed up of calling people out to check it and not much being done about it. cold water flow is absolutely fine and stop tap is fully open. all valves are open underneath the boiler.
any info would be greatly appreciated.
thankyou
thankyou
