Doesn't explain the low flow rate and the reason it's so hot is because it's going through your boiler so slowly and picking up lots of heat. Your boiler doesn't have a temperature control but it does have a temperature limit for the water, if it's going at a very low flow rate though it will hit the limit and cut out then come back on when it's cooled down (hence the original problem).
