Hi all,
Just looking for some advice on my boiler. The issue I have is that for some reason my boiler (Worcester 30CDI) is providing only warm water even though the central heating is piping hot.
Situation I had yesterday was that from the shower the water was warm and when I switched the bath tub taps on the water was quite hot and was so for about minute.
The change in the temperature in the water has only happened recently.
On the actual boiler settings i have always had the water function set to off and the when hot taps are on you can hear the boiler kick in, granted it takes few secs for the hot water to pump through. Like I said I have not changed this in over 2 years so why the water is coming out warm now I dont understand.
I have though set the water settings on 'on' and taken off the eco mode, something i read else where on this forum. its helped a little but more or less same issue.
any advice on anything else i can try/ what the issue is? do i need new parts etc and how much am i looking at!?!?
Cheers
Mike
Cheers
Mike
