i have a worcester combi 9.24 boiler in my flat 15 years old in quick succesion the pump gave up the ghost then the diverter valve needed replacing now i have a new problem which goes like this hot water and heating is very hot even when the temperature dial is at its lowest point if i move the dial up to anything near the max the pressure starts heading up eventually cutting out boiler i replaced the bits myself and have read that you should bleed the heat ex could this be problem or expansion vessel any ideas?
