worcester 9.24
Status
Not open for further replies.
5 Jan 2010
Gloucestershire
boiler fires up runs for alittle while then cycles off, it then wont relight, changed electrode and tried anew solenoid, pump works and the fan comes on. pressure is ok. it just seems to work as and when. any idears.
control stat ok. turns boiler of when turned down and switches boiler on again when turned up. fan and pump come on but no ignition.
Working on an air pressure switch or any components inside the combustion chamber should only be done by a gas registered engineer.
Status
