Worcester Bosch 24i with an annoying leak!
9 Aug 2008
Manchester
I have a leak on my 24i boiler.
A while ago I had to replace the pump head on my boiler because it had failed. At the time I also had a leak that I couldn't locate but assumed that it was the pressure relief valve releasing water due to the faulty pump. The pump head was replaced and works fine but, the leak is still there. I have now located the leak on the boiler drain point/pressure gauge connection. I have checked the manual and although this part is described, there are no instructions for it's removal/replacement.
My question is - "Can this be removed and replaced and if so, how is it done?"
Thanks in advance
Peadee
