My boiler has started playing up, this has become apparent since it summer switch off of the central heating system. The problem is the boiler only works up on till its first temperature control. If it has not been worked overnight or when we come home the when the boiler is cold it works fine, then the temperature of the thermostat has reached its desired figure. At this point it switches off when it has to reignite it is getting the signal but not striking up it just sits doing nothing. The hot water works perfectly still in any mode. The boiler when its warm can only made to work again by a full power switch and letting it reboot then it hits its target temp and I am back at square one. Any ideas
