- Joined
- 6 Aug 2013
- Messages
- 88
- Reaction score
- 0
- Country
I hope you can help.
I have a Worcester Bosch Combi boiler Eco Greenstar 30i
A day or so ago it stopped providing hot water so I checked the pressure and the gauge was near zero, so I repressurised the system (2nd time in 4 years) but the problem still persists.
What happens is you turn the tap on, it calls for heat and the boiler fires up, temps rise and on the temp dial on the front it gets into the 90's and shuts off, few seconds later it recycles and tries again.
If I press the "info" button it says "flow control sensor fault", which makes sense.
Anything I can try of is it an engineer call out?
(I also reset the boiler)
